Originally posted by BKE
View Post
New workstation budget 3000,00€ with double GTX670
Originally posted by MoonDoggie View PostPost your overclock voltages if you don't mind, and blk frequencies.
Thanks alvius's think Im due an upgrade!Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
Originally posted by Morne View Postwhat would be the time, stock for the 3930 without OC?
Though I have benchmarked most of the machines in the office with Cinebench 11.5. I could post them it that would be of any use.
A little tip. If your i7 runs too hot it WILL DECLOCK. So you have to monitor throttling(not sure how u call it) and fine tune ur settings. Or else it will start with 4.5ghz and then go down to 3.2 ghz once internal parameters go to red... Even if its at 65c or so... Its bit tricky with those i7s...
